[GRASS-dev] v.centroid: on boundaries only?
Hamish
hamish_b at yahoo.com
Fri Jan 27 15:57:01 EST 2012
Moritz ha scritto:
> typemask is not an option for v.centroid, but a grass-plugin
> specific parameter. What does it do ?
Paolo:
> it filters out the type of maps that appears on the list.
Martin:
> AFAIU, it's related to `type` parameter. `typemask` filters vector
> maps which contains given type, ie. in this case only vector maps
> which contains at least one area (closed set of boundaries) are shown
> in combo box.
Paolo:
> ok, so the current set of options seem right.
but v.centroids is important for cases when there are no valid areas.
e.g. a dxf line map deliniating land parcels converted to boundaries
with v.type.
Hamish
