[GRASS-dev] Re: [GRASS GIS] #1428: WinGRASS 6.4.1 fails to start
after installation
trac at osgeo.org
Sat Jan 28 01:25:20 EST 2012
#1428: WinGRASS 6.4.1 fails to start after installation
Reporter: dhastings | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Installation | Version: 6.4.1
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by majgis):
I had this issue on Windows 7 64bit
This page has an excellent explanation:
http://stackoverflow.com/questions/1596167/where-to-download-microsoft-
visual-c-2003-redistributable
Based on that information, I installed the three packages associated with
.NET Framework 1.1:
http://msdn.microsoft.com/en-us/netframework/aa569264 (install from bottom
up)
Grass 6.4.1 immediately started without the issue, no restart required.
I'm guessing a Python version earlier than 2.6 is being used. If you
upgrade the version of Python you are using, you might change the
dependency to a newer dll which is more likely to already be included on a
newer machine...but then XP users might require a newer service pack.
It is unfortunate you can't distribute the dll. A random thought...if you
accept the license agreement for visual C++ express, which is free, would
you be able to distribute it? I'm assuming you need a licensed copy of
Visual Studio (or free express version!) to redistribute.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1428#comment:3>
