[GRASS-dev] Re: [GRASS GIS] #1276: r.null after v.to.rast in
winGRASS does not work properly
trac at osgeo.org
Sat Jan 28 15:48:05 EST 2012
#1276: r.null after v.to.rast in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, v.to.rast, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hamish):
probably unrelated, but fyi,
spawn.c: In function 'parse_argvec':
spawn.c:739: warning: cast from pointer to integer of different size
spawn.c:742: warning: cast from pointer to integer of different size
spawn.c:748: warning: cast from pointer to integer of different size
spawn.c:749: warning: cast from pointer to integer of different size
spawn.c:755: warning: cast from pointer to integer of different size
spawn.c:762: warning: cast from pointer to integer of different size
spawn.c:763: warning: cast from pointer to integer of different size
spawn.c:764: warning: cast from pointer to integer of different size
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:22>
