[GRASS-dev] Re: [GRASS GIS] #1428: WinGRASS 6.4.1 fails to start
after installation
trac at osgeo.org
Sat Jan 28 16:28:03 EST 2012
#1428: WinGRASS 6.4.1 fails to start after installation
Reporter: dhastings | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Installation | Version: 6.4.1
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by majgis):
>fwiw, http://msdn.microsoft.com/library/ms171868.aspx "The .NET
Framework 4 is highly compatible with applications that are built with
earlier .NET Framework versions, except for some changes that were made to
improve security, standards compliance, correctness, reliability, and
performance."
From what I remember, .net 1.x and 2.x-beyond was a fundamental shift, but
I'm shooting from the hip here. Also, these dlls are not part of the .Net
framework, so it makes sense that microsoft would make a change to provide
them as part of a separate redistributable package, another guess.
>even if a test program caught the error, sometimes it is not very
specific about the cause (e.g. when it quits with just [Error 14001]) and
you just have to "know" that installing the extra dlls fixes it. Since
osgeo4w is a moving target, if we hard-code in the missing dll and its
download URL we could always be one step behind.. (shrug)
There should never be an error. We now know what redistributable package
is required, during installation you can peek at the registry, if it isn't
there, you provide messages or option to download.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1428#comment:10>
