[GRASS-dev] Re: [GRASS GIS] #1276: r.null after v.to.rast in
winGRASS does not work properly
trac at osgeo.org
Mon Jan 30 04:32:21 EST 2012
#1276: r.null after v.to.rast in winGRASS does not work properly
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Raster | Version: 6.4.1 RCs
Keywords: r.null, v.to.rast, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:22 hamish]:
> probably unrelated, but fyi,
spawn.c: In function 'parse_argvec':
spawn.c:739: warning: cast from pointer to integer of different size
Known issue, not actually a problem, no obvious solution.
Casting from pointer to a larger integer type to int would eliminate the
warning, but there's no obvious candidate for the larger integer type. C89
has neither intptr_t nor "long long"; in fact, there's no guarantee that a
given C89 has any integral type capable of holding a pointer.
In the cases where the cast occurs, the pointer is required to be an "int"
which has been cast to a pointer, so casting back to "int" isn't a
problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1276#comment:23>
