[GRASS-dev] Re: [GRASS GIS] #1139: v.report has a problem (only via
OSGEO4W package)
trac at osgeo.org
Mon Jan 30 05:12:22 EST 2012
#1139: v.report has a problem (only via OSGEO4W package)
Reporter: naokiueda | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Vector | Version: 6.4.2 RCs
Keywords: wingrass, v.report, osgeo4w | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hamish):
Apparently the '#!/bin/sh -x' has no effect here. Could you add the "set
-x" somewhere near the start of the script?
could you try running this command from the osgeo4w terminal prompt:
v.db.select -c geology | sort -n -t'|' -k 1 | head
I suspect the problem is DOS's sort.exe is being used by osgeo4w instead
of msys's version of sort.exe, as seen in #1553. (what does `which sort`
at the msys prompt say? /bin/sort.exe?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1139#comment:13>
