[GRASS-dev] temporal: gettext warnings
Glynn Clements
glynn at gclements.plus.com
Mon Jan 30 13:08:00 EST 2012
Martin Landa wrote:
> ../lib/python/temporal/datetime_math.py:227: warning: 'msgid' format
> string with unnamed arguments cannot be properly localized:
> The translator cannot reorder the arguments.
> >> They could be fixed by splitting the message [1] ...
> > [1] is the wrong thing to do ...
> I am not sure if we are speaking about same thing.
I'm talking about "splitting the message".
IIUC, the issue relates to strings with more than one substitution. If
the substitutions are matched with parameters by position (i.e. the
first substitution uses the first parameter, etc), the translated
string cannot have the parameters in a different order, even if that
would be appropriate for a particular language.
Splitting the message (so that each translated string contains a
single substitution) might eliminate the warnings (I don't know
whether it does, but I assumed that was the idea behind the "splitting
the message" suggestion), but it won't do anything about the issue
which caused the warning.
