[GRASS-dev] Re: [GRASS GIS] #1139: v.report has a problem (only via
OSGEO4W package)
trac at osgeo.org
Mon Jan 30 14:34:19 EST 2012
#1139: v.report has a problem (only via OSGEO4W package)
Reporter: naokiueda | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Vector | Version: 6.4.2 RCs
Keywords: wingrass, v.report, osgeo4w | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:15 hellik]:
> Replying to [comment:13 hamish]:
> > could you try running this command from the osgeo4w terminal prompt:
> v.db.select -c geology | sort -n -t'|' -k 1 | head
> Welcome to GRASS 6.4.2svn (2012)
> GRASS homepage: http://grass.osgeo.org/
> This version running thru: Bourne Shell (/bin/sh)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> GRASS 6.4> v.db.select -c geology | sort -n -t'|' -k 1 | head
> 1|963738.75|4083.97998|2|1|Zml|963738.608571|4083.979839
> 2|22189124|26628.261719|3|2|Zmf|22189123.2296|26628.261112
> 3|579286.875|3335.55835|4|3|Zml|579286.829631|3335.557182
> 4|20225526|33253|5|4|Zml|20225526.6368|33253.000508
> 5|450650720|181803.765625|6|5|Ybgg|450650731.029|181803.776199
> 6|6386874.5|17978.429688|7|6|Zml|6386875.00182|17978.430892
> 7|969311.1875|4096.096191|8|7|Ybgg|969311.720138|4096.098584
> 8|537840.625|3213.40625|9|8|Zmf|537840.953797|3213.407197
> 9|3389078.25|16346.604492|10|9|Zml|3389077.17888|16346.604884
> 10|906132.375|4319.162109|11|10|Zml|906132.945012|4319.163379
tested above with a completely fresh downloaded osgeo4-stack (the old
osgeo4-stack ,which my earlier tests above were based upon, was more than
2 years old). now also v.report invoked from the wx-gui is working.
so for the original bug-reporter, please test again with a completely
fresh osgeo4w-stack/osgeo4w-wingrass.
I tend to suggest closing the ticket.
Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1139#comment:16>
