[GRASS-dev] Re: [GRASS GIS] #1553: osgeo4w and qgis builds: path settings to msys on wingrass find wrong 'sort'
GRASS GIS trac at osgeo.org
Tue Jan 31 00:28:05 EST 2012
'sort'
 Reporter:  sbl                      |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  major                    |   Milestone:  6.4.2
Component:  Packaging                |     Version:  6.4.2 RCs
 Keywords:  wingrass, osgeo4w, qgis  |    Platform:  MSWindows XP
      Cpu:  Unspecified              |
Comment(by hamish):
 Replying to [comment:4 sbl]:
 > I can confirm that:
 > v.db.select --verbose map=grid columns=cat where="cat>10"
 > works on a fresh installation of OSGeo4W, though, v.report
 > and sort do not.
 what does `which sort` say? how about `which echo`?
 do /bin/sort.exe and /bin/echo.exe exist?
 are you running the commands from a MSys rxvt terminal prompt, a cmd.exe
 DOS box, or the wxGUI command-line entry box?
 In your $PATH /bin comes before /c/WINDOWS/system32, so I'm not sure why
 it wouldn't pick up /bin/sort.exe if it was there.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1553#comment:5>
