[GRASS-dev] in trunk png/cairo d.vect overwrites previous images?
Moritz Lennert
mlennert at club.worldonline.be
Tue Jan 31 05:15:47 EST 2012
On 31/01/12 11:01, Patrice Dumas wrote:
> On Tue, Jan 31, 2012 at 10:36:01AM +0100, Moritz Lennert wrote:
>> This behaviour is controlled by the GRASS_PNG_READ environment variable.
>> If you set it to TRUE, then GRASS will lay the new d.vect on top of the
>> already drawn vectors, otherwise it overwrites with the new. See
>> http://grass.osgeo.org/grass70/manuals/html70_user/cairodriver.html.
> Thanks. I was pretty sure I missed something although I did read the
> Fine Manual before asking... Maybe the GRASS_PNG_READ description
> could be enhanced by adding
> Otherwise the GRASS_PNGFILE file content is overwritten each time
> a new display command is used.
Will do, thanks for the suggestion.
> Also I think that the Example should also set
> export GRASS_PNG_READ=TRUE
> otherwise it doesn't really make sense as the elevation raster will not
> appear on map.png.
Here's what I see as example on the page:
export GRASS_RENDER_IMMEDIATE=cairo
export GRASS_WIDTH=800
export GRASS_HEIGHT=800
g.region rast=elevation
d.rast map=elevation
d.vect map=streams width=1 color=blue fcolor=aqua type=area,line
d.vect map=roadsmajor width=2
i.e. GRASS_PNG_READ is set... :-)
Moritz
