[GRASS-dev] [GRASS-user] GRASS, ArcGIS, and Python incompatibilties
Mon Jul 2 18:54:46 PDT 2012
Michael Barton wrote:
> > 2. Changed the Init.bat file in %GISBASE%\etc so that %PYTHONPATH%
> > (which was present because of my ArcGIS python instlalation) was no
> > longer part of the PYTHONPATH variable at GRASS startup.
> > before:
> > set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python;%GISBASE%\etc\wxpython
> > after:
> > set PYTHONPATH=%GISBASE%\etc\python;%GISBASE%\etc\wxpython
If the Windows installer is bundling Python, this change is correct.
If PYTHONPATH is already set prior to starting GRASS, there's no
reason to believe that the directories to which it refers contain
packages which are compatible with the bundled Python.
