[GRASS-dev] [GRASS GIS] #1685: r.in.ascii -s for SURFER does not work in grass7
trac at osgeo.org
Wed Jul 4 20:16:43 PDT 2012
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: raster import, Surfer, r.in.ascii | Platform: All
Cpu: OSX/Intel |
Changes (by hamish):
* keywords: raster import, Surfer => raster import, Surfer, r.in.ascii
* platform: MacOSX => All
Comment:
the error message in g7 lib/gis/seek.c is now just "Unable to seek"; it's
not a fundamental limitation just a regular bug AFAICT.
I found a binary Surfer6 grid file sitting on an old drive, and could
convert it to an ascii grid:
gdal_translate -of GSAG helens2.grd helens2a.grd
r.in.ascii -s in=helens2a.grd out=helens2
and I can reproduce your error. It happens in r.in.ascii/main.c on this
G_fseek(), while processing the last row of the map.
for (row = 0; row < nrows; row += 1) {
fread(rast, Rast_cell_size(data_type), ncols, ft);
Rast_put_row(cf, rast, data_type);
G_fseek(ft, sz, SEEK_CUR);
fclose(ft);
unlink(temp);
Rast_close(cf);
G_ftell(ft) reports the position as 1308 but G_fseek() wants to move
sz=-2616 bytes (negative as surfer ascii grids are stored bottom to top),
and runs past the end (i.e. start) of the file. note 1308*2 = 2616. I
presume the array is off by 1 row and the first line of data is either
repeated or empty.
here is row, nrows, sz, and on the newline G_ftell() position for the last
few rows:
460 466 -2616
7848
461 466 -2616
6540
462 466 -2616
5232
463 466 -2616
3924
464 466 -2616
2616
465 466 -2616
1308
ERROR: Unable to seek
The import works fine in grass 6.x.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1685#comment:1>
