[GRASS-dev] [GRASS GIS] #1684: configure GRASS 6 with X11 support
GRASS GIS trac at osgeo.org
Thu Jul 5 00:11:09 PDT 2012
 Reporter:  martinl         |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.3
Component:  Compiling       |     Version:  svn-releasebranch64
 Keywords:  configure, X11  |    Platform:  Linux
      Cpu:  x86-64          |
Comment(by wenzeslaus):
 Same or similar problem on Ubuntu 12.04 32bit on 64bit machine for GRASS
 7.
 Even after setting the proper path to X11:
   --x-includes=/usr/include/ --x-libraries=/usr/lib/
 and succesfull configure with ''X11... yes'', compilation itself fails
 (e.g for nviz lib). The problem was missing header file `StdCmap.h` (or
 files) from package libxmu-dev.
 For me the solution was to install package libxmu-dev.
 This header file(s) should be explicitly checked by the configure script
 to avoid these confusions.
 BTW: There are several other issues with configure: it does not check
 wxPython version (instead, some error dialog is shown on start up) and it
 does not check presence of numpy (temporal and gui dependency, Ubuntu
 package python-numpy).
 (Related wiki page for Ubuntu:
 http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1684#comment:3>
