[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Pierre Roudier pierre.roudier at gmail.com
Thu Jul 12 16:47:08 PDT 2012
Sorry, my bad:
roudierp at mangatainoka:~/.config/Terminal$ apt-file find xmkmf
xmanpages-ja: /usr/share/man/ja/man1/xmkmf.1.gz
xutils-dev: /usr/bin/xmkmf
xutils-dev: /usr/share/man/man1/xmkmf.1.gz
So on ubuntu, xmkmf and imake are available through the xutils-dev
package. However, I still run into the same error at compilation,
P
2012/7/13 Pierre Roudier <pierre.roudier at gmail.com>:
> Glynn,
> Is there an easy work-around this? It's a bit weird as the compilation
> goes well on my older machine. It seems to fail only on this newer
> configuration. After a bit of googling, I *think* that the xutils-dev
> package, which provides imake, does not provide the xmkmf script
> anymore.
> I don't think I'm making any use of the ximgview module at the moment,
> so I'm happy to try and drop it from my final install. I do need
> grass7 to compile for testing Eric Momsen's GSoC project.
> Any help greatly appreciated,
> Cheers,
> P
> 2012/7/13 Glynn Clements <glynn at gclements.plus.com>:
>> Pierre Roudier wrote:
>>> : && gcc -L/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib
>>> -Wl,--export-dynamic
>>> -Wl,-rpath-link,/usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/lib
>>>  -o /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/ximgview
>>> OBJ.x86_64-unknown-linux-gnu/color.o
>>> OBJ.x86_64-unknown-linux-gnu/main.o    -lgrass_gis.7.0.svn -L -lX11
>> The problem is the bare -L switch, which causes -lX11 to be treated as
>> an argument to -L rather than a separate switch.
>> Unfortunately, the AC_PATH_XTRA test which sets X_LIBS is part of
>> autoconf, and not something which can easily be worked around.
>> First it tries using imake (xmkmf), which may not exist on modern
>> systems. If that fails, it tries a fixed set of plausible library
>> directories, all of which use "lib" rather than e.g. "lib64", as the
>> latter wasn't in common use when autoconf-2.13 was released (Jan
>> 1999).
>> It may be time to think about moving to a newer version of autoconf.
>> It's much more stable now than it was in the period immediatley after
>> 2.13.
> Scientist
> Landcare Research, New Zealand
Scientist
