[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Pierre Roudier
pierre.roudier at gmail.com
Fri Jul 13 15:29:04 PDT 2012
Thanks heaps for your help Glynn, it worked.
For reference, here's the workaround I used:
roudierp at mangatainoka:/usr/local/src/grass_trunk$ more
include/Make/Platform.make | grep -n XLIB
86:XLIBPATH = -L/usr/bin
Cheers,
Pierre
2012/7/14 Glynn Clements <glynn at gclements.plus.com>:
> Pierre Roudier wrote:
>> Is there an easy work-around this?
> Provided that the configure script completes, you can edit
> include/Make/Platform.make by hand. The relevant variables are
> XLIBPATH and XLIB.
Scientist
Landcare Research, New Zealand
