[GRASS-dev] limits of r.patch
Margherita Di Leo
dileomargherita at gmail.com
Tue Jul 17 07:42:28 PDT 2012
On Tue, Jul 17, 2012 at 4:34 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> >ERROR 4: `ASTGTM_N33E000_dem_lzw.tif' does not exist in the file system,
> >and is not recognised as a supported dataset name.
> what says gdalinfo about ASTGTM_N33E000_dem_lzw.tif?
gdalinfo ASTGTM_N33E000_dem_lzw.tif
Driver: GTiff/GeoTIFF
Files: ASTGTM_N33E000_dem_lzw.tif
Size is 3601, 3601
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-0.000138888888889,34.000138888888891)
Pixel Size = (0.000277777777778,-0.000277777777778)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_DATETIME=2008:10:28 20:03:51
TIFFTAG_DOCUMENTNAME=created at
TIFFTAG_IMAGEDESCRIPTION=SILC TIFF
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
TIFFTAG_SOFTWARE=IDL 6.3, Research Systems, Inc.
TIFFTAG_XRESOLUTION=100
TIFFTAG_YRESOLUTION=100
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -0.0001389, 34.0001389) ( 0d 0' 0.50"W, 34d 0' 0.50"N)
Lower Left ( -0.0001389, 32.9998611) ( 0d 0' 0.50"W, 32d59'59.50"N)
Upper Right ( 1.0001389, 34.0001389) ( 1d 0' 0.50"E, 34d 0' 0.50"N)
Lower Right ( 1.0001389, 32.9998611) ( 1d 0' 0.50"E, 32d59'59.50"N)
Center ( 0.5000000, 33.5000000) ( 0d30' 0.00"E, 33d30' 0.00"N)
Band 1 Block=3601x1 Type=Int16, ColorInterp=Gray
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120717/f65271c7/attachment.html>
