[GRASS-dev] limits of r.patch
Helmut Kudrnovsky
hellik at web.de
Tue Jul 17 07:50:29 PDT 2012
>>what says gdalinfo about ASTGTM_N33E000_dem_lzw.tif?
>oh, I've meant: gdalinfo mosaic.vrt
tested here now with some aster-tiles:
C:\data\gisdata\asterdem\Tiles_201102121133>gdalinfo asterdem.vrt
Driver: VRT/Virtual Raster
Files: asterdem.vrt
C:\data\gisdata\asterdem\Tiles_201102121133\ASTGTM_N42E006\ASTGTM_N42E006
\ASTGTM_N42E006_dem.tif
C:\data\gisdata\asterdem\Tiles_201102121133\ASTGTM_N43E004\ASTGTM_N43E004
\ASTGTM_N43E004_dem.tif
C:\data\gisdata\asterdem\Tiles_201102121133\ASTGTM_N43E005\ASTGTM_N43E005
\ASTGTM_N43E005_dem.tif
Size is 10801, 7201
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (3.999861111111111,44.000138888888891)
Pixel Size = (0.000277777777778,-0.000277777777778)
Corner Coordinates:
Upper Left ( 3.9998611, 44.0001389) ( 3d59'59.50"E, 44d 0' 0.50"N)
Lower Left ( 3.9998611, 41.9998611) ( 3d59'59.50"E, 41d59'59.50"N)
Upper Right ( 7.0001389, 44.0001389) ( 7d 0' 0.50"E, 44d 0' 0.50"N)
Lower Right ( 7.0001389, 41.9998611) ( 7d 0' 0.50"E, 41d59'59.50"N)
Center ( 5.5000000, 43.0000000) ( 5d30' 0.00"E, 43d 0' 0.00"N)
Band 1 Block=128x128 Type=Int16, ColorInterp=Gray
linking with r.external also works here:
r.info map=asterdemlinked at asterdem
| Layer: asterdemlinked at asterdem Date: Tue Jul 17 16:44:24 2012
| Mapset: asterdem Login of Creator: myricaria
| DataBase: \grassdata
| Title: ( asterdemlinked )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 7201
| Columns: 10801
| Total Cells: 77778001
| Projection: Längen- und Breitengrad
| N: 44:00:00.5N S: 41:59:59.5N Res: 0:00:01
| E: 7:00:00.5E W: 3:59:59.5E Res: 0:00:01
| Range of data: min = 0 max = 642
| Data Description:
| generated by r.external
| Comments:
| r.external input="C:\data\gisdata\asterdem\Tiles_201102121133\asterd\
| em.vrt" output="asterdemlinked"
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/limits-of-r-patch-tp4988265p4988835.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
