[GRASS-dev] limits of r.patch
Markus Metz
markus.metz.giswork at gmail.com
Wed Jul 18 01:42:33 PDT 2012
On Wed, Jul 18, 2012 at 9:00 AM, Margherita Di Leo
<dileomargherita at gmail.com> wrote:
> Hi,
> On Tue, Jul 17, 2012 at 4:51 PM, Margherita Di Leo
>> Now tried:
>> gdalbuildvrt -input_file_list elenco_aster_europa mosaic.vrt
>> (all in the same folder)
>> then in GRASS:
>> GRASS 6.4.3svn (ASTER_GDEM):~ > r.external
>> input=/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt output=mosaic --verbose
>> Projection of input dataset and current location appear to match
>> Proceeding with import...
>> Importing band 1 of 1...
>> Setting grey color table for <mosaic> (data range)
>> Creating support files for mosaic
>> Link to raster map <mosaic> created
>> GRASS 6.4.3svn (ASTER_GDEM):~ > r.info map=mosaic
>> | Layer: mosaic Date: Tue Jul 17 16:49:06 2012
>> | Mapset: PERMANENT Login of Creator: leomarg
>> | Location: ASTER_GDEM
>> | DataBase: /forest/GRASS/grassdata
>> | Title: ( mosaic )
>> | Timestamp: none
>> | Type of Map: raster Number of Categories: 0
>> | Data Type: CELL
>> | Rows: 140401
>> | Columns: 198001
>> | Total Cells: 27799538401
>> | Projection: Latitude-Longitude
>> | N: 72:00:00.5N S: 32:59:59.5N Res: 0:00:01
>> | E: 44:00:00.5E W: 11:00:00.5W Res: 0:00:01
>> | Range of data: min = 0 max = 0
>> | Data Description:
>> | generated by r.external
>> | Comments:
>> | r.external input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt"
>> output="mos\ |
>> | aic"
> I've imported the same map with r.in.gdal:
> r.in.gdal input=/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt output=mosaic
> --overwrite
> r.info map=mosaic
> | Layer: mosaic Date: Tue Jul 17 17:57:31 2012
> | Title: ( mosaic )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 6518
> | Data Type: CELL
> | Rows: 140401
> | Columns: 198001
> | Range of data: min = -9999 max = 6518
> | Data Description:
> | generated by r.in.gdal
> | Comments:
> | r.in.gdal input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt" output="mosa\
> | ic"
> So I guess something is wrong with r.external..
Maybe it helps if you use the -r flag with r.external, otherwise the
range will not be correct.
Markus M
