[GRASS-dev] po-strings f=?iso-8859-1?B?/A==?=r r.mapcalc
Wed Jul 18 11:15:04 PDT 2012
Markus Neteler wrote:
> what is the best way to get this long r.mapcalc/main.c message into the
> .po files?
> static const char help_text[] =
>     "r.mapcalc - Raster map layer data calculator\n"
>     "\n"
>     "usage: r.mapcalc '<map>=<expression>'\n"
>     "\n"
>     "r.mapcalc performs arithmetic on raster map layers.\n"
>     "\n"
>     "New raster map layers can be created which are arithmetic expressions\n"
>     "involving existing raster map layers, integer or floating point constants,\n"
>     "and functions.\n" "\n" "For more information use 'g.manual r.mapcalc'\n";
Does enclosing the string in _(...) not work?
