[GRASS-dev] po-strings für r.mapcalc
Maris Nartiss
maris.gis at gmail.com
Fri Jul 20 01:26:23 PDT 2012
Hello Markus,
You can't use function to initialize a array (string) in C (Glynn can
correct me, if I'm wrong).
I just moved help text to main to be able to extract that string in
r52421 for 6.4.
Cheers,
Maris.
2012/7/19 Markus Neteler <neteler at osgeo.org>:
> On Wed, Jul 18, 2012 at 8:15 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Markus Neteler wrote:
>>> what is the best way to get this long r.mapcalc/main.c message into the
>>> .po files?
>>> static const char help_text[] =
>>> "r.mapcalc - Raster map layer data calculator\n"
>>> "\n"
>>> "usage: r.mapcalc '<map>=<expression>'\n"
>>> "\n"
>>> "r.mapcalc performs arithmetic on raster map layers.\n"
>>> "\n"
>>> "New raster map layers can be created which are arithmetic expressions\n"
>>> "involving existing raster map layers, integer or floating point constants,\n"
>>> "and functions.\n" "\n" "For more information use 'g.manual r.mapcalc'\n";
>> Does enclosing the string in _(...) not work?
> For me no, I get in the last row:
> error: invalid initializer
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
