[GRASS-dev] GUI for v.in.ogr
Johannes Radinger JRadinger at gmx.at
Fri Jul 20 02:22:19 PDT 2012
> > Hi,
> > I don't know if this behavior is intended or not, I just
> > wanted to inform:
> > Using the GUI and selecting File -> Import vector data
> > -> Common Import Formats (v.in.ogr) provides a different
> > window compared to typing v.in.ogr into the command console...
> > (in GRASS 6.4.3SVN).
> That's intentional:
> - the window above has been developed with multi-file support in mind
> - the module's v.in.ogr window is autogenerated from the module
> Would you like to see this changed?
I was just a little confused as I wasn't aware that there are two different types of windows...Maybe just the "(v.in.ogr)" in the line "Common Import Formats" is misleading and suggesting getting the autogenerated window of the v.in.ogr module.
/Johannes
> Markus
