[GRASS-dev] [GRASS GIS] #1688: ps.map: adding negative scale and offset to vpoints plotting -- patch provided
GRASS GIS trac at osgeo.org
Fri Jul 20 03:08:10 PDT 2012
provided
 Reporter:  alf             |       Owner:  grass-dev@…
     Type:  enhancement     |      Status:  new
 Priority:  normal          |   Milestone:
Component:  Ps.map          |     Version:  svn-develbranch6
 Keywords:  ps.map vpoints  |    Platform:  All
      Cpu:  Unspecified     |
 Hello,
 herein you find a patch that will enable negative scaling and introduces
 offset for vpoints representation in ps.map.
 This will be useful if you are dealing with representation of vpoints
 symbols scaled by negative attribute values.
 This patch introduces also the '''offset''' parameter in vpoints so it
 will be possible to shift the scaling values (useful when the values are
 both positive and negative).
 In this patch documentation has be updated consequently.
 please try the patch, revise improve and/or apply to GRASS!
 Best,
 Alessandro Frigeri
Ticket URL: <http://trac.osgeo.org/grass/ticket/1688>
