[GRASS-dev] grass not building against new ffmpeg
Fri Jul 20 04:51:29 PDT 2012
Markus Neteler wrote:
>   --with-ffmpeg --with-ffmpeg-includes="/usr/include/ffmpeg
> /usr/include/ffmpeg/libav* /usr/include/ffmpeg/libpostproc
> /usr/include/ffmpeg/libswscale" \
Note that wildcard expansion is not performed inside quoted strings.
Also, for recent versions of FFMPEG, the #include directive in
gsd_img_mpeg.c:
	#include <avformat.h>
is incorrect. The directories are now part of the header name, so it
should be:
	#include <libavformat/avformat.h>
The directory containing the libav* subdirectories must be in the
include path.
