[GRASS-dev] po-strings für r.mapcalc
Maris Nartiss
maris.gis at gmail.com
Fri Jul 20 07:45:49 PDT 2012
Just my curiosity as I'm not a good programmer (more coder than
programmer) - why using large string literal in fputs is so bad idea?
Maris.
2012/7/20 Glynn Clements <glynn at gclements.plus.com>:
> Maris Nartiss wrote:
>> You can't use function to initialize a array (string) in C (Glynn can
>> correct me, if I'm wrong).
> Correct.
> You can't use a function call to initialize static variables (i.e.
> global variables or "static" local variables) or any array (whether
> static or automatic).
> I was thinking about it from the xgettext side (i.e. whether xgettext
> recognises concatenated string literals split over multiple lines)
> rather than from the C side, so I completely overlooked that issue.
> From the C side, using:
> const char *help_text = _("...");
> inside main() would work. That may be preferable to putting a large
> string literal inside the fputs() call.
