[GRASS-dev] [GRASS GIS] #1690: r.to.vect: `dbf` proc segfaults if MAPSET/dbf/ dir is missing
trac at osgeo.org
Thu Jul 26 04:38:37 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.3
Component: Database | Version: 6.4.2
Keywords: r.to.vect, dbf | Platform: Linux
Cpu: x86-32 |
I'm just testing out the live dvd quickstart,
http://adhoc.osgeo.osuosl.org/livedvd/docs/en/quickstart/grass_quickstart.html
using spearfish location and elevation.10m as the input map, the dbf
process crashes during the r.to.vect step. but if you immediately run it
again it's fine. this is in a fresh mapset, there is a VAR file (which
looks ok), but there was not a dbf/ dir yet. (I've now fixed the live dvd
install script to force creation of that dir when it makes the mapset)
when you run r.to.vect you get a segfault in the `dbf` program. if you
allow overwrite, then click on [Run] again it works! so it seems that
r.to.vect is recovering from there being no dbf/ dir and making it, but
only too later after it was already fatal to the spawned dbf process.
programs should never segfault, so maybe the first thing to do is add more
error checking to dbf.c, then try to figure out how to get the dependency
checks in the correct order, or block until they are finished.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1690>
