[GRASS-dev] r51975, vlib: improve PostGIS topology support, introduce level 3
Markus Metz
markus.metz.giswork at googlemail.com
Wed Jun 6 07:14:02 PDT 2012
On Wed, Jun 6, 2012 at 3:27 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2012/6/6 Martin Landa <landa.martin at gmail.com>:
>> I was worried about introducing level 3 in this sense, you just made
>> me sure, that it was not a good idea. I will revert it back to the two
>> levels (keep level 3 for 3D topology).
> applied in r51984. Martin
Thanks!
BTW, when you're done implementing PostGIS topology, could you provide
a sample script to play around a bit with the new functionality?
Thanks again!
Markus M
