[GRASS-dev] [GRASS GIS] #1671: grass/script/setup.py errors
trac at osgeo.org
Thu Jun 7 09:28:30 PDT 2012
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Python | Version: 6.4.2
Keywords: | Platform: All
Cpu: Unspecified |
grass/script/setup.py needs a {{{os.pathsep}}} at this line
## os.environ['PATH'] += os.path.join(gisbase, 'lib') ##WRONG##
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'lib')
then $GISBASE/extralib and $GISBASE/msys/bin are missed in PATH (for
windows only)
## added for winGrass
if sys.platform.startswith('win'):
'extralib')
'msys','bin')
of course we need
{{{import sys}}}
at the beginning
Another point ----
From outside Grass Gis we '''must''' define $GISBASE, $GISRC and add
$GISBASE/etc/python to sys.path BEFORE import anything from grass
(I did'nt find anything about this in Programmer's Manual)
os.environ['GISBASE'] =gisbase
grass_python_dir= os.path.join(gisbase, 'etc','python')
if os.path.isdir(os.path.join(grass_python_dir,'grass')):
sys.path.append(grass_python_dir)
else:
raise Exception('etc\python\grass module not found')
os.environ['GISRC']= 'junk'
from grass.script import setup
gisrc= setup.init(os.getenv('GISBASE'),gisdb,location,mapset)
os.remove(gisrc)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1671>
