[GRASS-dev] [GRASS GIS] #1674: r.cross problems when overlaying layers with no-data
trac at osgeo.org
Wed Jun 13 02:09:59 PDT 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: r.cross, no data | Platform: Linux
Cpu: x86-64 |
When overlaying two layers that contain large areas of 'no data', r.cross
seems to assign random values to raster cells with no-data, even when
using the -z flag. See for example the output of r.what for a point where
both input layers have no data but the raster cell get's assigned a value
(30114 in the example below):
r.what --v -f -n input=wdpaPNV at ConsStat
coordinates=1549281.412639,-1312241.263941
easting|northing|site_name|wdpaPNV at ConsStat|wdpaPNV at ConsStat_label
1549281.412639|-1312241.263941||30114|no data; no data
Probably because of this problem, r.cross cannot be run on large layers
with large areas of no-data, it just get's stuck
Paulo
Running GRASS 7.0.svn (2012) on Ubuntu 12.04
Ticket URL: <http://trac.osgeo.org/grass/ticket/1674>
