[GRASS-dev] [GRASS GIS] #1675: Grass GIS wxPython startup error
trac at osgeo.org
Fri Jun 15 07:18:32 PDT 2012
Reporter: grruddy | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: | Platform: Linux
Cpu: x86-64 |
Comment(by neteler):
Relevant part of error copied here:
Welcome to GRASS 6.4.2 (2012)
GRASS homepage: http://grass.osgeo.org/
This version running thru: TC Shell (/bin/tcsh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Mapset <PERMANENT> in Location <spearfish60>
GRASS 6.4.2 > Traceback (most recent call last):
File
"/usr/local/intel64/nehalem/gcc/grass-6.4.2/grass-6.4.2/etc/wxpython/wxgui.py",
line 1721, in <module>
sys.exit(main())
File
line 1714, in main
app = GMApp(workspaceFile)
File
line 1605, in __init__
wx.App.__init__(self, False)
File "/usr/local/wx/wxWidgets-2.8.12.1/site-
packages/lib64/python/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in
__init__
self._BootstrapApp()
packages/lib64/python/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in
_BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File
line 1657, in OnInit
workspace = self.workspaceFile)
File
line 128, in __init__
self._createMenuBar()
File
line 232, in _createMenuBar
self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
File
"/usr/local/intel64/nehalem/gcc/grass-6.4.2/grass-6.4.2/etc/wxpython/gui_modules/menudata.py",
line 202, in __init__
MenuData.__init__(self, filename)
File
line 49, in __init__
self.tree = etree.parse(filename)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 862, in parse
tree.parse(source, parser)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 586, in parse
parser.feed(data)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 1245, in feed
self._parser.Parse(data, 0)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xc6 in position 1:
invalid continuation byte
*** glibc detected *** python: double free or corruption (out):
0x0000000001776a50 ***
======= Backtrace: =========
/lib64/libc.so.6[0x3a16275296]
/lib64/libexpat.so.1(XML_ParserFree+0x32)[0x3a19e04d12]
/usr/lib64/python2.6/site-
packages/_xmlplus/parsers/pyexpat.so(+0x791b)[0x7fc4084e491b]
/usr/lib64/libpython2.6.so.1.0[0x3a2887f3eb]
/usr/lib64/libpython2.6.so.1.0[0x3a28858074]
/usr/lib64/libpython2.6.so.1.0[0x3a2886ce42]
/usr/lib64/libpython2.6.so.1.0[0x3a2890435b]
/usr/lib64/libpython2.6.so.1.0[0x3a2890436b]
======= Memory map: ========
Ticket URL: <http://trac.osgeo.org/grass/ticket/1675#comment:1>
