[GRASS-dev] Report #4, GSoC, GRASS Image Segmentation
Eric Momsen
eric.momsen at gmail.com
Fri Jun 15 22:54:25 PDT 2012
TGIF!
It is fun to be into the guts of the coding.
Completed:
* Segmentation will run on tiny maps, using arrays. This demonstrated
algorithm steps are sound, resulting segments were correct.
* Started to implement some linked lists to increase the size of the map
that can be processed.
Next week:
* Finish linked list implementation.
* Add polygon constraints for preexisting segmentation boundaries.
Blocking:
Nothing has stopped me for very long, I continue to have great support from
my mentors. My challenge this week (well, I suppose this is a common
challenge!) was balancing the urge to write fast and finish large chunks of
code against taking the time to test and proceed carefully to avoid
introducing bugs.
Regards,
Eric
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120616/08442777/attachment.html>
