[GRASS-dev] [pygrass] should I use ctypes or cython?
Sören Gebbert soerengebbert at googlemail.com
Wed Jun 20 00:47:55 PDT 2012
Hi Pietro, dear developers,
i think we should stay with ctypes as this is already supported by GRASS.
Also the benchmark results are looking very promising regarding
efficiency to me.
Best regards
Soeren
2012/6/19 Pietro <peter.zamb at gmail.com>:
> Dear all,
> I'm going on with the GSoC, and I'm using ctypes to call the Grass's
> function, but I found this comment:
> http://stackoverflow.com/a/5686873
> (from a cython developer) that it has instilled in me a doubt that
> using Cython (http://cython.org/) could make pygrass more
> flexible/extensible. From my point of view I prefer ctypes, because it
> is already inside grass and because I need to get something running
> quickly, but maybe could be more useful for Grass to implement less
> code but with a tool that give more flexibility in the future...
> What do you think?
> Can I go on with my GSoC project using ctypes? should i switch to Cython?
> I did some benchmarks to test the speed of pygrass, and it is not too
> bad. Below I reported the execution time of add a number to a Raster
> map,  using r.mapcal module, the RasterRow class (using Rast_get_row,
> and Rast_put_row functions), and using the Segmentation library
> (segment_get_row and segment_put_row):
> r.mapcalc +2; 21.487251 sec/pass
> RasterRow +2; 11.181928 sec/pass
> RasterSeg +2; 14.730741 sec/pass
> Test an if condition:
> r.mapcalc if; 14.240596 sec/pass
> RasterRow if; 14.753899 sec/pass
> RasterSeg if; 19.982334 sec/pass
> Test a function:
> r.mapcalc sqrt; 16.495872 sec/pass
> RasterRow sqrt; 18.591585 sec/pass
> RasterSeg sqrt; 22.305732 sec/pass
> You may find the code here:
> git clone https://code.google.com/p/pygrass/
> and you can run the benchmark code with:
> python test/benchmark.py
> more info on the RasterRow and RasterSegment classes are available here:
> http://pygrass.readthedocs.org/en/latest/raster.html
> Comments are welcome!
> Best regards,
> Pietro
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
