[GRASS-dev] gettext warnings
Sören Gebbert
soerengebbert at googlemail.com
Wed Jun 20 01:41:26 PDT 2012
Hi Anna,
thanks for the reminder. It is on my todo list but with low priority,
since the temporal GIS framework is still in early development phase
and i focus on usability, functionality and module documentation right
now.
I will respect the guideline when writing/updating messages in the
temporal framework. When i begin with code polishing, the messages get
fixed.
Best regards
Soeren
2012/6/20 Anna Kratochvílová <kratochanna at gmail.com>:
> Hi,
> I would like just to remind you of the warnings which you get after
> 'make pot' in ./locale. The warnings came from ./lib/python/temporal.
> Here is the related ticket [1] and mail discussion [2].
> This problem can be solved using:
> message = _("Selected map <%(map)s> is not in current mapset <%(mapset)s>. " %
> { 'map' : self.mapName, 'mapset' :
> grass.gisenv()['MAPSET'] }
> Perhaps we could add a note to the SUBMITTING_PYTHON document?
> Anna
> [1] http://trac.osgeo.org/grass/ticket/1677
> [2] http://lists.osgeo.org/pipermail/grass-dev/2012-January/057674.html
