[GRASS-dev] Usage of size_t
Vaclav Petras
wenzeslaus at gmail.com
Thu Jun 21 08:16:30 PDT 2012
Hello,
I'm moving size_t topic from user to dev list.
As I understand, size_t should be used also for number of rows and
number of columns of a map. But for example Rast_window_{rows,cols}
returns int. So will this be also changed/fixed to size_t?
Note that some instances of using int instead of size_t can be
identified by GCC warning option -Wsign-conversion. It marks usage of
int as an argument of malloc/G_calloc/... or usage of int for
iterating C++ STL containers.
Vaclav
>From topic "NVIZ can't allocate enough memory" on [GRASS-user]:
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Tue, Jun 12, 2012 at 5:23 AM
> Subject: Re: [GRASS-user] NVIZ can't allocate enough memory
> To: Daniel Lee <lee at isi-solutions.org>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Daniel Lee wrote:
>> ERROR: G_malloc: unable to allocate 18446744071974792324 bytes at gsds.c:575
> 18446744071974792324 = 0xffffffff9899ac84
>> Does anybody know what could be the problem? If I'm interpreting the bytes
>> correctly, that'd be about 10^10 gigabytes, which several orders of
>> magnitude larger than the rasters involved. Thanks!
> A calculation has overflowed the range of a signed 32-bit integer
> resulting in a negative value. This value has then been converted to a
> signed 64-bit integer, and then to an unsigned 64-bit integer.
>> Here's the output of g.region:
>> rows: 32001
>> cols: 20001
>> cells: 640052001
> At 4 bytes per cell, 640052001 cells = 2560208004 bytes.
> 2560208004 = 0x9899ac84
> The maximum value representable by a 32-bit integer is 0x7fffffff =
> 2147483647.
> Using an unsigned integer would eliminate the problem in this
> particular case, but the region wouldn't need to be much larger in
> order for that to be insufficient (specifically, 32001 x 33553 would
> overflow).
> The correct solution is to use "size_t" rather than "int". E.g. for
> this specific case:
> --- gsds.c (revision 52015)
> +++ gsds.c (working copy)
> @@ -481,7 +481,8 @@
> int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
> dataset *ds;
> - int i, siz = 1;
> + int i;
> + size_t siz = 1;
> if ((ds = get_dataset(id))) {
> More generally, it's important that the conversion comes before the
> mulitply; e.g.:
> size_t cells = (size_t) rows * cols;
> will work but:
> size_t cells = rows * cols;
> won't; the calculation will be perfomed using "int", overflow, then
> the overflowed result will be promoted.
> However: the number of instances of this particular issue in the GRASS
> source code is probably somewhere between "dozens" and "hundreds", and
> there's no systematic way to identify them. Running test cases with a
> region of >= 2^32 cells (or even >= 2^29 cells, i.e. >= 2^31 bytes at
> 4 bytes per cell) would find a lot of them, but it requires a 64-bit
> system with plenty of RAM, and it's going to be slow.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
