[GRASS-dev] [GRASS GIS] #778: i.rgb.his, i.his.rgb: propagate NULLs
trac at osgeo.org
Mon Jun 25 13:00:51 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: i.rgb.his, i.his.rgb | Platform: All
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 cmbarton]:
> Is this difficult to fix?
Not really.
In 7.0, nulls resulted in garbage. 7.0 doesn't have an equivalent of
G_get_map_row(), but rgb2his/his2rgb don't explicitly check for nulls, so
they will be treated as the literal value -2147483648. This should be
fixed by r52207.
In 6.x, change G_get_map_row() to G_get_c_raster_row() in main(), then
manually back-port r52207.
Also, we might want to do something about the hard-coded 0..255 range
(r.composite uses the colour table to convert cell values to intensities),
but that's a separate issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/778#comment:2>
