[GRASS-dev] PCA question
Nikos Alexandris
nik at nikosalexandris.net
Wed Jun 27 05:34:24 PDT 2012
[Addendum]
Hamish:
> > (not talking about pan-sharpening, but in general,)
> > how about the situation where you have a map data
> > which is loudly dominated by a signal, and you want to try and remove that
> > loud signal so that you can look at the subtle variations caused by a
> > different source that the loud signal had been masking?
Nikos:
> Yes, this _can_ be a perfect use-case.
> Especially if the presence of the feature in question, is in at least one or
> in some of the input dimensions near/close to zero. This last statement is
> based on Pielou's (flawless explanation of how PCA works) [1] and own
> experiences [2].
If the above holds true (near-zero projection, in one or some dimensions, of
the features of interest), and in some way, these "subtle variations" do form
distinct clusters, I'd be keen to try out non-centered PCA and (re-)confirm
Pielou and myself (claiming, for example, higher Producer's accuracies as in
--my-- burned area mapping).
Nikos
> A separation/isolation attempt of the feature in question from dominant
> variances will be "supported". The "loud" signal would be channeled among
> the first few PCs and the "subtle variations" _could_ then be more evident
> in some of the higher order components.
> All in all, one has to look at the numbers -- drawing conclusions from the
> PC images is not safe!
