[GRASS-dev] [GRASS GIS] #1682: incorrect output from v.voronoi
trac at osgeo.org
Sat Jun 30 16:28:37 PDT 2012
Reporter: MichaelP | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: v.voronoi | Platform: Linux
Cpu: x86-64 |
v.voronoi is generating nonsensical data. At times it appears to be
generating correct output, but at other times, the data generated is
corrupted. The attached data set is one such data set that triggers it to
generate incorrect output.
The attached data set is a subset from a LiDAR point cloud in ascii
format. Nad83 UTM 15N.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1682>
