[GRASS-dev] call for gsoc ideas
Martin Landa landa.martin at gmail.com
Mon Mar 5 07:18:54 EST 2012
Hi all,
I went through GRASS GSOC ideas [1] to make the list a little bit more
up-to-date. I would ask you to do the same, add a new ideas, and so
on. Some topics need to be discussed, eg.
* wxGUI (1, creating animations) - some work has been done by Anna
after her GSoC project [2]
* i.class replacement - work is in progress (Anna & Vaclav) - [3] (GRASS 7 only)
* ... and some others
Thanks for your time which you spend with GSoC. Martin
[1] http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012
[2] http://grass.osgeo.org/wiki/WxNviz#Animations
[3] http://grass.osgeo.org/wiki/WxIClass
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
