[GRASS-dev] Re: [GRASS GIS] #1598: Exit call in some libs
GRASS GIS trac at osgeo.org
Mon Mar 5 15:36:23 EST 2012
 Reporter:  volter       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  6.4.2
 Keywords:  shared lib   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [ticket:1598 volter]:
 > Some of the Grass libraries call exit. Probably you can do something
 about it!
 The standard error-handling mechanism in GRASS is to call G_fatal_error(),
 which calls exit(). Most other libraries probably shouldn't be calling
 exit() directly, but should be calling G_fatal_error() instead.
 FWIW, the list of library files which call exit() directly is:
 lib/linkm/oom.c
 lib/iostream/ami_stream.cpp
 lib/vector/diglib/allocation.c
 lib/db/dbmi_driver/driver.c
 lib/form/open.c
 lib/raster3d/maskfn.c
 lib/rst/data/dataquad.c
 lib/gis/parser_help.c
 lib/gis/error.c
 lib/gis/parser.c
 lib/gis/gisinit.c
 lib/driver/init.c
 plus most of the CDHC library.
 libgrass_sqlp's exit() is from yy_fatal_error(), which is part of the lex
 boilerplate. If desired, error handling can be customised by defining the
 macro YY_FATAL_ERROR.
 Some of the above are legitimate, others may indicate code which should be
 lib/vector/diglib/allocation.c uses G_calloc(), so it doesn't need to
 perform its own error handling (although dig__frealloc() should just use
 G_realloc()).
 The other cases should be examined, but most of these are invalid/wontfix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1598#comment:1>
