[GRASS-dev] [GRASS GIS] #1599: netcdf input upside down raster
trac at osgeo.org
Tue Mar 6 12:43:36 EST 2012
Reporter: michpaulatto | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: 6.4.0
Keywords: input netcdf upside down raster | Platform: Linux
Cpu: x86-64 |
What I'm trying to do: I'm importing netcdf elevation and/or gravity grids
(.grd) into grass.
The problem: imported raster is sometimes upside down
Example: two netcdf grid files generated with GMT's grdsample. dem.grd and
grav.grd, see below output of grdinfo:
% grdinfo dem.grd [[BR]]
dem.grd: Title: dem.grd[[BR]]
dem.grd: Command: grdsample -R173/193/-39/-15 -I0.02 Complete_merged.grd
-Gdem.grd[[BR]]
dem.grd: Remark:[[BR]]
dem.grd: Gridline node registration used[[BR]]
dem.grd: Grid file format: nf (# 18) GMT netCDF format (float) (COARDS-
compliant) [DEFAULT] [[BR]]
dem.grd: x_min: 173 x_max: 193 x_inc: 0.02 name: longitude [degrees_east]
nx: 1001[[BR]]
dem.grd: y_min: -39 y_max: -15 y_inc: 0.02 name: latitude [degrees_north]
ny: 1201[[BR]]
dem.grd: z_min: -10804.1416016 z_max: 714.619628906 name: z[[BR]]
dem.grd: scale_factor: 1 add_offset: 0[[BR]]
% grdinfo grav.grd [[BR]]
grav.grd: Title: grav.grd[[BR]]
grav.grd: Command: grdsample -R173/193/-39/-15 -I0.1 temp
-Ggrav.grd[[BR]]
grav.grd: Remark: [[BR]]
grav.grd: Gridline node registration used[[BR]]
grav.grd: Grid file format: nf (# 18) GMT netCDF format (float) (COARDS-
grav.grd: x_min: 173 x_max: 193 x_inc: 0.1 name: x nx: 201[[BR]]
grav.grd: y_min: -39 y_max: -15 y_inc: 0.1 name: y ny: 241[[BR]]
grav.grd: z_min: -270.356201172 z_max: 203.824752808 name: z[[BR]]
grav.grd: scale_factor: 1 add_offset: 0[[BR]]
When I import these two files into grass (from the GUI) dem.grd results in
a correct raster while grav.grd results in an upside down raster. This
happens with other grd files I've tried, but this example is quite
interesting since the two grd files cover the same area, have the same
dimensions and have been generated in exactly the same way. They have
different grid spacing. Any clues?
Thanks. Michele.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1599>
