[GRASS-dev] [GRASS GIS] #1610: Restructure the file layout to
comply to the FHS
trac at osgeo.org
Sun Mar 11 17:40:34 EDT 2012
#1610: Restructure the file layout to comply to the FHS
Reporter: volter | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: unspecified
Keywords: /usr/lib | Platform: Unspecified
Cpu: Unspecified |
I suppose this topic is not new to you and it's on the to-do-list of many
distribution packagers:
Please restructure the file layout to comply to the file hierarchy
standard.
http://www.pathname.com/fhs/
Many or most GNU/Linux distributions require packages to follow these
guidelines to even be included. Grass was introduced into Fedora at a
time, when quality assurance wasn't as tight as it is today. Nevertheless,
these changes should be made.
The files installed to /usr/lib and subdirectories are the most prominent
violations.
"/usr/lib includes object files, libraries, and internal binaries that are
not intended to be executed directly by users or shell scripts."
For Grass, besides that, it also contains:
* Translations --> /usr/share/locale
* Python scripts --> /usr/share
* Data (icons, fonts, projection data) --> /usr/share
* Documentation --> /usr/share/man, /usr/share/doc
The arrows indicate where roughly we expect to find this kind of content.
I know, it is probably really hard to get all that working with the
GISBASE environment variable. For Fedora, my approach on the easier part
was, to hardcode the paths for locales and documentation -- replacing
GISBASE.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1610>
