[GRASS-dev] Re: [GRASS GIS] #1610: Restructure the file layout to
comply to the FHS
trac at osgeo.org
Tue Mar 13 05:30:23 EDT 2012
#1610: Restructure the file layout to comply to the FHS
Reporter: volter | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: Installation | Version: unspecified
Keywords: /usr/lib | Platform: Unspecified
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:2 volter]:
> Hi Maris, long time no see!
> "... and internal binaries that are not intended to be executed directly
by users or shell scripts"
You too ;)
Still I would also vote for "invalid", as I don't see any sense in having
an i.e. g.region man page if I can't run g.region command. GRASS already
has the only directly-run application in /usr/bin -> grass to launch a
GRASS session and the rest should be hidden from the outside of GRASS
session in a similar way how it is in the R.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1610#comment:4>
