[GRASS-dev] [GRASS GIS] #1616: WXGUI selecting to render a map and
map selection bind to same event in layer manager
trac at osgeo.org
Tue Mar 13 18:33:08 EDT 2012
#1616: WXGUI selecting to render a map and map selection bind to same event in
layer manager
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
When I click on the checkbox to render/disable map rendering in WXGUI
layer manager, the map is selected. Clicking on the next map's checkbox
will select it too.
Now when I try to get rid of this selection to have only one map selected
by clicking on map name - nothing happens.
When I click outside of checkbox and outside of map name, it gets
unselected, still it also triggers a rendering checkbox value change (i.e.
from "not render" to "render").
The problem comes from the fact, that checkbox and the background of map
layer entry both respond to same single event. Selecting a map to render
or not shouldn't change it's selection and selecting/unselecting map layer
shouldn't change it's rendering status. Current implementation makes
really hard to select and change rendering options for multiple map
layers.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1616>
