[GRASS-dev] Re: [GRASS GIS] #1614: WXGUI regression - attribute table management doesn't work
GRASS GIS trac at osgeo.org
Tue Mar 13 18:42:10 EDT 2012
 Reporter:  marisn       |       Owner:  martinl
     Type:  defect       |      Status:  assigned
 Priority:  major        |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  6.4.2
 Keywords:  atm          |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Changes (by martinl):
 * cc: grass-dev@… (added)
  * keywords:  => atm
  * status:  new => assigned
  * owner:  grass-dev@… => martinl
Comment:
 Well, calling it a "regression" is quite offensive expression;-) You
 should be allowed to modify only attribute tables which are linked to the
 maps from your current mapset, make sense to you? See title of tab which
 contains info about *readonly* mode.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1614#comment:1>
