[GRASS-dev] Re: [GRASS GIS] #1610: Restructure the file layout to comply to the FHS
GRASS GIS trac at osgeo.org
Fri Mar 16 01:26:30 EDT 2012
 Reporter:  volter        |       Owner:  grass-dev@…
     Type:  task          |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Installation  |     Version:  unspecified
 Keywords:  /usr/lib      |    Platform:  Unspecified
      Cpu:  Unspecified   |
Comment(by glynn):
 Replying to [comment:6 volter]:
 > Nevertheless, there are architecture independent files in /usr/lib, that
 don't belong there:
 That's because GRASS expects to find all of its files in fixed locations
 relative $GISBASE. The default location is /usr/local/grass-<version>, but
 can be changed via the --prefix option. Presumably whoever built the
 Fedora packages used --prefix=/usr/lib. Personally, I believe that
 /opt/grass-<version> would be more appropriate.
 GRASS isn't going to move away from the single-directory layout in the
 foreseeable future. That's too much work given the limited amount of
 manpower available.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1610#comment:7>
