[GRASS-dev] Re: [GRASS GIS] #1619: v.krige won't load: ImportError:
 No module named globalvar
    trac at osgeo.org
    Fri Mar 16 09:32:01 EDT 2012
#1619: v.krige won't load: ImportError: No module named globalvar
 Reporter:  momsen   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Default  |     Version:  svn-trunk
 Keywords:  krige    |    Platform:  Linux
      Cpu:  x86-64   |
Comment(by momsen):
 It is nice to hear I've finally gotten to the point where my installation
 wasn't at fault.  I have not yet updated/written code for any open source
 projects, but want to learn.  I have a presentation Tuesday, so if someone
 can provide guidance I could look at it then.  If you find time to make
 the update before that, I'm sure there will be other things I can help
 with later.
 I'm late for leaving for the weekend, I'll be able to check more on zoo
 and xts later.  Both can be loaded directly in R as well, from memory zoo
 was a dependency for one of the spgrass6 related packages.  At least it
 shows up each time I installed it!
 -Eric
Ticket URL: <http://trac.osgeo.org/grass/ticket/1619#comment:2>
