[GRASS-dev] Re: [GRASS GIS] #1603: v.surf.bspline won't interplolate across meridian 0
GRASS GIS trac at osgeo.org
Sat Mar 17 02:56:48 EDT 2012
 Reporter:  cmbarton        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.3
Component:  Raster          |     Version:  unspecified
 Keywords:  v.surf.bspline  |    Platform:  Unspecified
      Cpu:  Unspecified     |
Comment(by mmetz):
 Replying to [comment:1 cmbarton]:
 > Hmm. It doesn't work in GRASS 7 either. Also, points don't display
 across the Greenwich meridian in GRASS 7
 > It worked yesterday.  The only difference is that I just recompiled new
 versions of both 6.4.3 and 7 today. So it must have broken since 27
 February 2012. With the display problem too, this seems like something
 fairly major. Can someone check to see if they get the same problems?
 I can not reproduce the error. For a global dataset in latlon covering
 -180,180 longitude the full region is interpolated.
 Can you provide the full output of v.info of the input vector, r.info of
 the output raster and g.region of the current region? Thanks!
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1603#comment:3>
