[GRASS-dev] Re: [GRASS-user] error message from GRASS 7 on mac os
Michael Barton
Michael.Barton at asu.edu
Wed Mar 21 12:27:19 EDT 2012
OK. I've updated this in trunk and backported to 6.4 dev branch and release branch.
Michael
On Mar 20, 2012, at 2:46 AM, Anna Kratochvílová wrote:
> 2012/3/19 Michael Barton <Michael.Barton at asu.edu>:
>> Since wx.CallAfter does not solve this, the only sure-fire fix that I can find is to either revert to the standard wx.SplashScreen or to replace line 59 in wxgui.py with:
>> if SC and sys.platform != 'darwin':
>> That way, at least the Macs default to the basic splash screen without the errors. The AdvancedSplash does show the text "Starting GRASS GUI...", but that is the only thing lost by reverting the old splash screen
> I agree with the second solution (leaving the advanced splash screen
> for other platforms). Please don't forget to add a comment in the code
> about the reason. I suppose this problem might be fixed in the future.
> Anna
>> Michael
>> On Mar 18, 2012, at 1:44 PM, Anna Kratochvílová wrote:
>>> Hi,
>>> 2012/3/18 Michael Barton <Michael.Barton at asu.edu>:
>>>> I found the problem. It's the 'advanced splash screen' (in the agw package) called fromwxgui.py.
>>>> Although the advanced splash screen can do some additional things beyond the normal splash screen, we don't really use much (or any?) of those capabilities.
>>> I don't have any experience with it. You can try to use wx.CallAfter
>>> (as advised in the wxwidgets bug report) when setting splash screen.
>>> Something like:
>>> def SetSplashScreen(self, splashScreen):
>>> splashScreen.Set...
>>> if SC:
>>> splash = SC.AdvancedSplash(bitmap = introBmp, timeout = 2000,
>>> parent = None, id = wx.ID_ANY)
>>> wx.CallAfter(self.SetSplashScreen, splash)
>>> Again, I really don't know what's going on. I think it's not GRASS gui
>>> fault, problem seems to be in wxwidgets and Mac. The same for the next
>>> error message (CFURLCreateWithString ...), I doubt anything can be
>>> done by GRASS developers. Maybe some workaround exists but I can't
>>> google anything now.
>>> Anna
>>>> try:
>>>> import wx.lib.agw.advancedsplash as SC
>>>> except ImportError:
>>>> SC = None
>>>> if SC:
>>>> timeout = 2000, parent = None, id = wx.ID_ANY)
>>>> splash.SetText(_('Starting GRASS GUI...'))
>>>> splash.SetTextColour(wx.Colour(45, 52, 27))
>>>> splash.SetTextFont(wx.Font(pointSize = 15, family = wx.DEFAULT, style = wx.NORMAL,
>>>> weight = wx.BOLD))
>>>> splash.SetTextPosition((150, 430))
>>>> Every call to splash produces "<Error>: CGContextRestoreGState: invalid context 0x0"
>>>> Michael
>>>> On Mar 18, 2012, at 12:53 AM, Anna Kratochvílová wrote:
>>>>> 2012/3/17 Michael Barton <michael.barton at asu.edu>:
>>>>>> Anna,
>>>>>> Where did you insert this? I can do a quick test. I'd be delighted if we
>>>>>> could avoid those annoying error messages.
>>>>> Not sure what 'where' means, here [1] is the changeset. According to
>>>>> this email [2] the error message 'CGContextRestoreGState: invalid
>>>>> context' is supposed to show up immediately after wxGUI start. This
>>>>> fix is just a guess, I really don't understand what's going on. Are
>>>>> there any other annoying messages on Mac?
>>>>> Anna
>>>>> [1] http://trac.osgeo.org/grass/changeset/51089
>>>>> [2] http://lists.osgeo.org/pipermail/grass-user/2012-March/063996.html
>>>>>> Michael
>>>>>> Begin forwarded message:
>>>>>> Hi,
>>>>>> I added CallAfter as suggested (r51089), let's see if it helps.
>>>>>> Anna
>>>>>> _____________________
>>>>>> C. Michael Barton
>>>>>> Visiting Scientist, Integrated Science Program
>>>>>> National Center for Atmospheric Research &
>>>>>> University Consortium for Atmospheric Research
>>>>>> 303-497-2889 (voice)
>>>>>> Director, Center for Social Dynamics & Complexity
>>>>>> Professor of Anthropology, School of Human Evolution & Social Change
>>>>>> Arizona State University
>>>>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>>> C. Michael Barton
>> C. Michael Barton
C. Michael Barton
University Corporation for Atmospheric Research
