#1650: v.net.salesman - add sequence output
Reporter: gfleming | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:6 mlennert]:
> Just one small issue: when using sequence=- the result is printed to the
terminal before the build process output. This can be solved by using the
quiet flag, but is there any way to do this even without that flag ?
Glancing over the code, I don't see any other way than creating some
temporary buffer which can then be output later, so we would be at the
starting point of the problem again, except if there is a possibility to
buffer to a temp file and then print out the results at the end.
Done in r51602. The sequence is first written to a temp file and then at
the very end written to stdout.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1650#comment:7>
