[GRASS-dev] Adding NetCDF to GRASS7 configure
Sören Gebbert soerengebbert at googlemail.com
Wed May 16 04:58:03 EDT 2012
Dear all,
i would like to add a new configure option to enable NetCDF support in
GRASS7. The new module r3.out.netcdf that exports 3d raster maps as
three dimensional (space or space + time) NetCDF files and several
other planed modules will need this library. My question is how to
integrate NetCDF in the configuration process? I have patched the
files "configure.in"  and "Platform.make.in". Do i need to modify any
additional files? How should i generate the configure script with
autoconf, so that it is compatible with the current configure script?
The "configure.in" and "Platform.make.in" patch is attached.
Many thanks in advance.
Best regards
Soeren
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20120516/fa9245bd/netcdf.obj
