[GRASS-dev] [GRASS GIS] #1660: RFE: add new batch= command line
option to main grass7 startup script
trac at osgeo.org
Fri May 18 23:24:36 EDT 2012
#1660: RFE: add new batch= command line option to main grass7 startup script
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Startup | Version: svn-trunk
Keywords: GRASS_BATCH_JOB | Platform: All
Cpu: All |
to make running GRASS_BATCH_JOBs a bit easier to use (and to avoid the
common :-) mistake of not `unset`ing it after), it would be nice if the
main grass7 startup script could parse the command line argv[] options for
batch=, check that the script exists and is executable, then use it
instead of looking for a GRASS_BATCH_JOB enviro variable?
perhaps with that done GRASS_BATCH_JOB could be retired for GRASS 7.0?
(or would there still be some reason to keep it as an alternate method?)
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1660>
